I cannot imagine why a guy like you thinks it is hilarious to attemp to insult someone who suggests running a main earth in with single cables when installing a sub-main, firstly wrong I have worked in factories and installed cable trays ladders, trunkings etc, I see the state of them at times as well and know they can still do the job, however what is so laughable about advising someone to run an earth wire in as a main earth? just because you have the name engineer and a high postcount and a few friends on here it doesnt impress me sonny, i wouldn't employ you with that attitude thats for sure, why not run an earth? why risk the trunking if you don't need to? surely it is good practice to do this if possible!!!
one statement comes to mind with you
small mans syndrome
oh and stop following me around the forum.
it is fine to have a view, i repect that, but to say any electrician installing an earth wire with the main phase cables in a system where a metal trunking is evident is in experienced just proves to me your in-experienced or do not like discussion regarding installation, there have been 3 or 4 other opinions here I am interested in and they didn't need to attempt to gain attention by trying to look the big man insulting a new member, (you can't afford me) probably the case, my firm only turns over 500k a year and is small compaired to most, one thing we don't do down here is cut corners on installations, right or wrong we always allow to install seperate earths in out fixed priced quotations, it doesn't mean we are thick, clueless and inexperienced.
Kind Regards
Disappointed in you tony, I am only stating a view regarding running an earth wire with submain cables, theres no need to jump on the bandwagon, I would respect you more if you gave an opinion, I am not trying to cause any trouble here, but believe if the forum wants to grow it needs views from across the spectrum tony, and slating a new member with experience in the trade because he suggests to an OP running an earth wire is a good bet is quite frankly appalling.
quote Tony
I would use singles keep everything contained and out of sight. The trunking if done properly should be your CPC.
I think he already did :flowers:
Reply to the thread, titled "Sub Main Supply" which is posted in Commercial Electrical Advice on Electricians Forums.
