Sup bonding code for property with no rcd | Page 3 | on ElectriciansForums
Discuss Sup bonding code for property with no rcd in the UK Electrical Forum area at ElectriciansForums.net
What code would you give when doing EICR for a property that has no supplementary bonding in a bathroom, there is no RCD on any circuit but zs and insulation tests are good,
Is it acceptable to measure the resistance between the shower and pipework, if it's under 0.05 ohm's take it as bonded, incase the bonding had been done but covered up?
I’m not loosing anything nor is this a debate where it has a looser in it, that is obviously how you view the world I take it?
Regarding outside the room would concern bonding of any pipework that meets the definition of an extraneous conductive part, that serves the location and is made in close proximity to the bathroom.
It’s obviously going nowhere apart from pointless insults started by you so perhaps it’s you who is ‘loosing ‘I’m not budging and neither are you so best leave it there.
Reply to Sup bonding code for property with no rcd in the UK Electrical Forum area at ElectriciansForums.net
Surely one of the most important parts of supplementary bonding is to bond the radiator and hot tap/pipe to the cold one. Both the hot tap and...
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
