Any one ever had the supernova apart mine blew its plug fuse repeatedly so I took it apart under the key pad housing there was a sheet of metal sticky paper with a copper bit glued onto it and a bit of wire soledered to that, all this is definatly home made because the screw fixing holes were cut out with scissors and I can see pen marks around the outer edge where its been cut out, any one know what this is for and is it a home made version of what should be in there and what would it do any way oh the wire it was scerwed onto the key pad gubbins
Pict
Pict
