Supplementary Bonding on a boiler | on ElectriciansForums
Discuss Supplementary Bonding on a boiler in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Monkeyhanger Land
Does supplementary bonding on a boiler have to be a continuous piece of cable or can you cut it & use yellow crimped terminals? Yes it is eega and by NICEIC requirements...
cheers all...
it does not have to be continuous. question is whether it needs to be done anyway.
obviously they are a prime example of a little knowledge being dangerous. " if it's metal, bond it ". back to 1980's and the 15th edition.
think IQ and a few other members who are a bit more theoretical than me could explain it better. by bonding at the boiler, you could be introducing an earth potential where it could increase the danger of electric shock. the theory's in me head, but i struggle to translate it into words at times.
Had a massive argument with NIC technical over zone bonding and introducing a fault current to bathroom / shower rooms, though might have been 16th
cheers all...
As it's unlikely to be a requirement of the BRB unless in a special location you can do it in wet string if you want to.
Who or what is/are eega?
Not this lot presumably:
East European Gas Analysis
Is this an oil or gas boiler.
If oil it will need 'cross bonding'. If gas it will not.
4mm will be okay. Just put your clamps on the pipes and go from clamp to clamp with cut lengths. No need for it to be continuous across all clamps.
Reply to Supplementary Bonding on a boiler in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
H
Boiler Programmer I have a wall mounted thermostat which is connected to a 26 volt supply from my Glowworm 24ci boiler. I would like to replace...
homebrewer55
H
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
