David DMC
I have a doubt, I'm searching the circuit of a bathroom and I've discovered a water pipe that has been repaired using a plastic connector. I know that is unsafely, but I'm not sure what to do. Thank you
Discuss Supplementary bonding in the UK Electrical Forum area at ElectriciansForums.net
https://www.youtube.com/watch?v=v38PfIVy2rI Have a look at this vid it may help.
I didn't expect that answer, but I need to know if isn't always necessary, how many times you should use SB and when not. Thank you
Reply to Supplementary bonding in the UK Electrical Forum area at ElectriciansForums.net
