supplementary bonding | on ElectriciansForums
Discuss supplementary bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gixerpete
I have installed a new tap in my bathroom and have used a plastic connector, can I link the pipes across the connector?
not sure what the situation is. if the existing pipes are still bonded and it's just the new tap you're concerned about, if that is connected with plastic, don't do anything.
If it requires supp bonding the put the link in like you say.
Was at a job yesterday where there was a plastic tee on the water supply. Just thought i'd check to see if there was continuity either side of the tee and it only showed as 0.02 ohm.
So much for plastic push fit totally breaking continuity
Was there water in the pipe when you tested it? if so the continuity would have been through the water.
Reply to supplementary bonding in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Surely one of the most important parts of supplementary bonding is to bond the radiator and hot tap/pipe to the cold one. Both the hot tap and...
The chances of any problem without the RCD are minimal, including it extremely negligible......with the supplementary, on a kin to Hannibal Lector...
