Surely there must be a Reg against this?! | Page 2 | on ElectriciansForums
Discuss Surely there must be a Reg against this?! in the UK Electrical Forum area at ElectriciansForums.net
SSE
My neighbour has put up a large garage that sits alongside his house but not joined to it. He asked me to wire & fit out lights inside & sockets as well. Told him he needs to get SWA to supply it as he was insisting on runnning the supply in (save money I assume) & for some reason (mainly cos he's tight) he's went & put a plastic pipe from the house to the garage & run a 10mm twin & earth & a 10mm earth through it!! It looks rough as & to be honest I'm pretty annoyed as the cable was going to be run underground to in ducting to supply it. He's adamant he's leaving it like that unless he's breaking any rules! Anyone help?!?! If there's Reg that's not being complied with he'd have no option than to do it the way I said!
thats how they do it in in New World:[video=youtube;vJeJvk_0Exc]http://www.youtube.com/watch?v=vJeJvk_0Exc[/video]
skip the video to the end part, looks like twin and earth been buried there and no one bothers :)
Thanks for the advice chaps. I spoke with the mans wife tonight & she informed me she'd rather there was no pipe going from between the house & the garage! Not wanting to cause them a huge hike in price, I suggested to her that I could run the SWA from the garage to inside the house loft (a distance of about 8m) & then just join it in a joint box (not the best I know but believe me a lot better than the visible pipe) throught to the house CU. She's more than happy with this she said. I think if I suggested this way in the first place her husband may have been OK with this, I think he just wasn't keen on a 25m run in SWA because of the price. It's not going to take half an hour to dig the trench & luckily for me my mate has a day off next week & says he'll do it for me (yes he's one of those that can't sit still on a day off unlike me!!). It wasn't even a 10mm T & E he ran in either it was a 6mm! Will still be fine though as it's just a ring & 4 strip lights & I'm sure there ain't going to be a massive voltage drop in a 25m run! Going to try & figure out how to post a picture on here as I took one earlier just to let you's see what he'd done.
Here's the picture. Not the worst you've seen I'm sure but I just wasn't wanting to put my name to it, where I live word spreads quick so something rough like this wouldn't do me any favours!
[ElectriciansForums.net] Surely there must be a Reg against this?!
hmm.....would`v been easier to just get a bit of armoured....and go method D with it...
Yeah I know but there was no telling him!! His wife has given me go ahead to run armoured from garage cu to inside property & put it in a joint box in attic then T&E to cu. It's not the best having to join it but going to have to compromise as they guy obviously doesn't want to spend much money. Least this way it will look tidy & I've not got people thinking I'm rough!
well.....its your job gall.....so of course its your call.....
after all you will be responsible for certing this....
think i would avoid jointing onto some twin though with a throughbox (presumably)....
hmm......take `instruction` from his Mrs.......let her deal with `im when the time comes...lol....
at least you know it will be as it should be....in reality...
Yes, maybe I'll just check the prices tomorrow as surely there can't be much of a difference between the price of what's already run in (6mm t+e and a 10mm earth) and 6mm SWA on it's own. I'm no certain but I'm pretty sure the price when I got 6mm SWA 3 core the other week it was around about ÂŁ2.40 per metre.
No one seems to have picked up on the conduit been plastic (electrical conduit assumed) isnt ideal for the environment its in namely that
in the summer sunlight it will heat up on one side quicker than the other and buckle and warp, this can nip/trap the cable.
Another point is white pipe unless stated lacks UV tolerance and will degrade and become brittle very quickly, its difficult to tell from pic how the conduit is attached at either end and how its sealed as you will find the rain will readily run down to the lower point along the conduit.
Ive just had a callout to the exact same thing a garden shed with a 20mm white pvc conduit from house which had warped and sliced into the very cable its supposed to protect also it was showing UV damage too to add to this, upon enquiry she told me the guys from B&Q did it for her when they took old shed away and fitted new one last year, no rcd protection etc etc need i say more!
That doesn't look too hideous, I was expecting far worse from the description, I would be reluctant to replace it if that's what the guy wanted, he's happy with it obviously, although it sounds like the boss his Mrs doesn't like it so that the end of it
Reply to Surely there must be a Reg against this?! in the UK Electrical Forum area at ElectriciansForums.net
