Surely there must be a Reg against this?!
My neighbour has put up a large garage that sits alongside his house but not joined to it. He asked me to wire & fit out lights inside & sockets as well. Told him he needs to get SWA to supply it as he was insisting on runnning the supply in (save money I assume) & for some reason (mainly cos he's tight) he's went & put a plastic pipe from the house to the garage & run a 10mm twin & earth & a 10mm earth through it!! It looks rough as & to be honest I'm pretty annoyed as the cable was going to be run underground to in ducting to supply it. He's adamant he's leaving it like that unless he's breaking any rules! Anyone help?!?! If there's Reg that's not being complied with he'd have no option than to do it the way I said!
Ah, never heard it called that before! Don't ask what made me think I had to pull it but for some reason I thought whole installation had to be isolated.
well....the prob you may have is things like knockout boxes...being connected to the installs MET....through the CPCs...but also being connected to earth...through the fabric of the building...so....
look....the point of it is to prove wether a supposed/suspected extranious conductive part (see definitions) is.....or not....
So the bullit stays in. I'll do this test & shall have my answers. Man I wish I was still doing maintenance, lol.
anyway.....knockout boxes would be considered exposed conductive parts....due to the 3.5mm screws securing fronts....
so take no notice of what i said at #65....lol...
anyway....off watchin football on iplayer...
bye..
Yeah no need to pull the main, just ir test between MET and the frame and if the reading is below 22 k ohms bond it if its above leave it
