Surface mounted cooker circuit | on ElectriciansForums
Discuss Surface mounted cooker circuit in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
London
Hi all,
I have been asked to install a new cooker circuit but the customer wants everything to be surface mounted to keep costs down. Do you know of any cooker connection units that are suitable for surface mounting e.g. have an appropriate back box? Cables will also be surface mounted using plastic conduit?
Many thanks,
M
Most of them, so long as the back box is deep enough.
Edit:-
40mm minimum to give yourself some wiggle room with the conductors.
Not sure about conduit connections... if you're talking conduit you'll probably have to carefully cut holes in the patress box. If you're actually meaning trunking, then the entry points will be plenty big enough. Some boxes even include cable clamps.
To avoid breaking the plastic boxes, cut the entry points with a junior hacksaw first, then break them out and clean up the edges with a file to prevent damage to the cable.
Further edit:-
And as it's a new circuit, it goes without saying it will need properly testing, an EIC and a building control notification. Depending on the size of the load, you may also want to consider the loading etc. in the consumer unit.
Reply to Surface mounted cooker circuit in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
