Surface mounted cooker circuit | Page 3 | on ElectriciansForums
Discuss Surface mounted cooker circuit in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
London
Hi all,
I have been asked to install a new cooker circuit but the customer wants everything to be surface mounted to keep costs down. Do you know of any cooker connection units that are suitable for surface mounting e.g. have an appropriate back box? Cables will also be surface mounted using plastic conduit?
Many thanks,
M
Or have you been snowed in, and got no beer :)
Been holed up with trageminal neuralgia apparently the worse pain known also referred to as the suicide pain, thank you to my docs for making it to the surgery today so your post gave me a right chuckle:D
Most of them, so long as the back box is deep enough.
Edit:-
40mm minimum to give yourself some wiggle room with the conductors.
Not sure about conduit connections... if you're talking conduit you'll probably have to carefully cut holes in the patress box. If you're actually meaning trunking, then the entry points will be plenty big enough. Some boxes even include cable clamps.
To avoid breaking the plastic boxes, cut the entry points with a junior hacksaw first, then break them out and clean up the edges with a file to prevent damage to the cable.
Further edit:-
And as it's a new circuit, it goes without saying it will need properly testing, an EIC and a building control notification. Depending on the size of the load, you may also want to consider the loading etc. in the consumer unit.
Hi Sparky,
I did actually mean trunking and not conduit sorry my bad!
Your info was much appreciated, thanks
Hi GK - you might like to get yourself updated to Trainee, which is you if I recall correctly :)
Hi Wilko,
Apparently to do that I have to be able to show I am currently on a course which im not. TBH im happy to be called whatever (within reason lol) as long as im able to use the site and knowledge of those wiser which comes in very useful!
Reply to Surface mounted cooker circuit in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
