SWA banjo. | on ElectriciansForums
Discuss SWA banjo. in the Talk Electrician area at ElectriciansForums.net
What do you do when making a SWA gland off
  • Total voters
    38
Leesparkykent
Nearly Esteemed
Kent
Just wondering what other sparks thoughts are on when making a SWA gland off. Do you generally fit the banjo inside the enclosure, outside the enclosure or piranha lock nuts every time on glands up to 25mm in size. Also there are no restrictions in/outside the enclosure to stop the banjo going inside or out (for arguments sake).
No real reason behind the poll just wanted to see what the general consensus is.
At the moment we use Piranha lock nuts on glands 20/25mm and Banjo's on gland sizes above. On our Main Switch Boards we don't use typical brass SWA glands we use top hat bolted glands, similar to that would typically be used for MV cable glanding... Hell of a lot easier to terminate say a 4 core 185mm or more SWA cable, especially in restricted spaces....
When I used to work on switch gear, always cleaned the outer casing of the metal enclosure with a small wire brush (in a battery drill later in life) to make sure it was nice and clean for a good contact with the Bango.
As DW said in #3 it’s circumstantial, you do what is required in the situation. You can vote all you like it’s immaterial.
Reply to SWA banjo. in the Talk Electrician area at ElectriciansForums.net
