Not voted in the poll as it depends on the box type you are glanding to. See a lot of banjo's externally on IP rated boxes with a hole drilled through the casing compromising the IP rating.
Use the pirana or earth nuts on plastic boxes makes installs quicker and neater and no IP is compromised.they are over a £1 each but worth it.
Not seen the wiska brass plates but they look good to me as putting any type of lock nut internally inside the box is a fiddly job due to the prethreaded holes. Cheers Leesparkykent will give them a try
That is a myth. Why does a 6mm hole with a bolt through it compromise the IP rating when the 20/25/32 etc.. hole next to it with a gland through it does not?
