SWA fault. | Page 2 | on ElectriciansForums
Discuss SWA fault. in the UK Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
never seen anything like this before. new cable supplied by cient, installed by ne. no probs. 2 weeks later get a call.. no power. continuity test proves brown conductor is o/c. client is in a catch22. has to return cable for replacement involving me 2 call-outs.... as a temp. measure, i rejigged it, using grey as L, BK as N, and armour as sole cpc. 8 wweks down the line, call to MCB tripped and won't reset. this is what i found after dissing the SWA completely.
[ElectriciansForums.net] SWA fault.cable was laid on ground prior to client digging trench, no chance of external damage. any ideas, apart from faulty manufacture?
Go back to the supplier/cable manufacturer for compensation if it's down to them, and advice. Can't see what else you can do, unless there are something dodgy electrical goings on.
client supplied the cable. he needs to take it back to supplier. after the 1st fault, i got power back on. client is then in a catch 22. can;t get new cable without taking original back. now it's failed completely, he's got no power to a location, but he'll have to manage till he gets his arse back to the supplier.
Not your problem Tel problem being I know you would like to help, all you can do is advise him
I can’t see any manufacture accepting that as a manufacturing fault. It would have failed the immersion test before leaving the factory.
Its been cut, probably with a chisel.
Cut a couple of metres out of it and put two joints in. Damp will have tracked down the cores and it’s usual to take a section out to get to where the interior is dry.
tony. the cable was installed lying on the ground, away from any hazards. within 2 weeks, the brown conductor went open circuit. there was no signs of damage. if it had been hit with a chisel or sharp implement, the armour would have been depressed from one side. it wasn't. and no signs of crushing.
Have had a decent zoom in on that pic, and have to agree that it's scuffed, pockmarked and just too cleanly broken to have been a form of 'explosion'. Methinks someone is telling you a mis-truth somewhere.
This is a wild, wild thought and is probably doing your customer an enormous injustice...but.....how confident are you it's the same cable? Because that looks as cut as a cut thing on cut day, and I bet under a microscope you'd see the saw marks. When all other possibilities have been eliminated, whatever remains (however unlikely) has to be the truth.
So thats a win, win for you then Tel.
You get paid to fault find, you get paid to install the replacement and the client gets the hassel of argueing with the supplier!
i don't know. but can't believe that th client ( who has supplied the cable) would damage it himself or let anyon e lse dot, then put it back in the undergrowth. bear in mind that the first failure was one conductor going o/c with a IR test between the other 2 and the armour showing clear. then this failure several weeks later. it's baffling me.
Hi,
Looking closely at the picture the armouring has got to have been cut, the wires are in alignment with each other; not ragged but looking like a saw cut. I see where you are coming from, but if I turned up on site that would be my first impression.
Look forward to hearing the final outcome.
Regards.
Reply to SWA fault. in the UK Electrical Forum area at ElectriciansForums.net
