SWA For meter tails? | Page 5 | on ElectriciansForums
Discuss SWA For meter tails? in the UK Electrical Forum area at ElectriciansForums.net
Msitekkie
Essex
I need to upgrade my meter tails to 25mm. The existing tails pass along under the pebble dash in plastic conduit (which would be too small), then apparently at an angle through the porch structure (unprotected) then turn sideways into a void & up the void to CU.
I have seen other posts where the use of SWA is suggested but I haven't actually seen SWA with 25mm cores. "25mm SWA" appears to be 25mm "Outside diameter", so I presume that means the cores are smaller.
Any suggestions as to the best approach welcomed. I actually think I will struggle with getting SWA through anyway even if it does exist with suitable cores, because of the bends involved.
NB The meter box is under the window of the house rather than on the side of the porch, but the void inside the porch is set back behind the run of the outside wall so it's not possible to drill directly through the outside porch wall into it.
Think of peak times morning evenings when most load will be consumed should only be short periods when applying diversity,
a bs88-3 (new bs number for 1361) will take 190a for half hour fig 3A1 bs1761
/QUOTE]
Thanks for that. Fig 3A1(page 319) is most illuminating. Few discussions of diversity refer directly to this time factor and its clearly very relevant.
PPP
Post pictures please
[ElectriciansForums.net] SWA For meter tails?
If it's SWA why would I use surface trunking? The problem I'm facing really, is once it reaches the porch getting it through the brickwork and wooden beam to the void. Ironically the supply to the meter appears to originate from somewhere under the concrete floor inside the porch, but moving the meter inside isn't really an option.
Trunking looks a little nicer than cleated SWA.
To get through the brickwork and wood drill a hole.
It’s not really ironic, it’s just probably been moved outside from it’s original location inside.
Reply to SWA For meter tails? in the UK Electrical Forum area at ElectriciansForums.net
You would treat it as a TT installation.
Thanks for the replies, I appreciate it.
