A
Andy Ellis
New supply for a shed (32A for hot tub + 16A power circuit)
Shed is 30 meter cable run from CU.
TN-C-S EARTH AT CU
Tub located in timber shed at bottom of garden, no services, water ect, will be filled by hosepipe when required.
Supplied from existing CU on own circuit, 60A 30mA RCD, Supplying 2 Way IP65 CU in shed.
I selected 2 core 6mm PVC SWA, assuming 25 degree ambient temp, clipped on its own to exterior wall. Max demand 47A or 11.04Kw (though cable would alow up to 50.5A) over 30M run I get drop to 10.5V or 4.6%
63A IP65 DP rotarty isolator on outside of shed.
This is as far as I got!
Struggling with the earthing and the PME. Lot of info on web that says it can not be exported to shed blah blah its endless!
I wondered if the best way would be to connect SWA to PME at the CU only, then TT the shed with a rod(s)... cant imagin that would be fun though... hmmm... and suppose it needs to be reliable with a hot tub involved!!!!?
Can you see any advantage to 3 core and using a core as earth, even if not connected on shed side and still TT shed
TN-C-S EARTH AT CU
