SWA/How deep? | Page 2 | on ElectriciansForums
Discuss SWA/How deep? in the Australia area at ElectriciansForums.net
J
Johno
How deep should an SWA cable be buried in the ground to officially comply with regs?
522.8.10 page 101 does not give a depth just states sufficient depth to avoid being damaged by any reasonably forseeable disturbance to the ground.
This is the correct answer. Pg 269 Note 1 relates to depth for the values in the tables for soil resistivity.:)
Only depth I can find is in 705.522, pg 185 maybe this contradicts the above.:eek: This is for farms etc. thought cables were always deeper on farms.:confused:
Or will this be ammended in the next issue?
Reply to SWA/How deep? in the Australia area at ElectriciansForums.net
You would treat it as a TT installation.
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
