I need to run a 4mm 3core SWA from a house (30mA RCD protected) approximately 10-15meters to supply a shed cu (which will only be switched on from the house when needed) consisting of a 20a radial with 3 sockets and 6a lighting circuit. The client isn't happy about having there flower beds dug up to bury the cable and there isn't a suitable fence for me to fix it to so the only option is to run in down the side of the garden laid surface through the flower bed tight to the fence. Looking through the regs I can't seem to find an exact reg for my situation giving a reason why i can't do it this way????
Section 705 agricultural and horticultural premise
-Protective measures:Automatic disconnection of supply -the swa will be protected by a 30mA RCD in the house
-It's not a location intended for livestock
-there's no risk of fire
-it's not in an area of agricultural premises where vehicles and mobile agricultural machines are operated
Am I right in saying there's no reason, all though its not the best method installation, why I can't run it down the side of the garden laid surface through the flower bed tight to the fence.
im hoping to use this job, as ive done quite a bit of work in the house including a cu upgrade and a few new circuits, as one of my assessment pieces for the NICEIC Domestic Installer scheme. I'm concerned as to wether I should carryout this method of installation for the swa as it seems to be a bit of a grey area and the client isn't really giving me any other option and I can't find a specific reg to back either argument as to the installation method. On one hand I definitely don't want to fail my assessment but I also don't want lose the job.
please help
please help
