SWA into plastic cu | Page 2 | on ElectriciansForums
Discuss SWA into plastic cu in the UK Electrical Forum area at ElectriciansForums.net
Truro
Hi guys just finishing off a rewire where I have a 6mm 3 core SWA Sub main running to an outbuilding. I'm connecting into a 10 way plastic cu in the house which is going to be positioned just under the ceiling in the hallway with the cable dropping down from above into it. Just wondered on the best way to connect the SWA I've heard people mention earthing nuts but never come across them. It is a T-N-CS earthing arrangement and is going on a 40a MCB, non RCD, protected running to a metal clad board in the outbuilding with the 3rd core used as the cpc and armour connected on the supply end. Any advice would be appreciated :)
What do you mean my a coupler with earth connection on ?
Can some of you old codgers explain XD
In the past when conduit was used as the cpc, they used couplers with a cpc connection on the outside so a piece of cable could be used to connect the cpc
found a pic
[ElectriciansForums.net] SWA into plastic cu
Pic didn't work, I can't say I've ever seen such a thing though, top hats are the only type of coupler I know of with better earth connections.
And what do you mean by in the past? Conduit is still used as the cpc.
Really?
You do much comerical/industrial?
a lot of designers spec cpc's in conduit now a day's.
Search in google for 20mm earth coupler and it be one of the first pics
Reply to SWA into plastic cu in the UK Electrical Forum area at ElectriciansForums.net
totally agree
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
