SWA joint the steel of a 2 core | Page 2 | on ElectriciansForums
Discuss SWA joint the steel of a 2 core in the UK Electrical Forum area at ElectriciansForums.net
London
Hi everyone,
I have a 2 core 10mm2 SWA from a DB to a consumer unit to be joint. I know seems a silly question but how can I joint the steel of the SWA?
Thank you
Thanks to everyone. It was very helpful. The client at the end brought up a 400m wooden cable druml of 3 core 10mm2 SWA!
what's the anticipated load. 400m is a long run. VD could be an issue.
Reply to SWA joint the steel of a 2 core in the UK Electrical Forum area at ElectriciansForums.net
I am with you. Their RCD did not comply with the standard. The only one I know that does comply, though I am sure it isn't alone, is the Garo...
Better off with the click prw213 as it has twin screw termination.
