M
Mwoods4757
Hi just after some help. It's a high rise block new install. Dno are wiring up to the Ryefield board then to the meter. Then there will be an isolator and then run to each flat cu. question is what size cable. I've been told 3 core 25 mm swa but this seems a bit excessive for 100a dp main switch in cu. the cu only has 9 ways with two 100a 30 ma rccb protection. 25 mm earth in cu will be hard to terminate too.
Also how would a 3 core terminate in the isolator. Would it not be better to use 16mm 2 core and separate earth?
