Swa sheath size too small | on ElectriciansForums
Discuss Swa sheath size too small in the UK Electrical Forum area at ElectriciansForums.net
london
an outbuilding is supplied by a 50mm twin SWA cable from a PME supply
The assessor has told me to convert to a TT as the steel csa is too small, is there a way I can prove that surely a 50mm twin swa sheath is suitable to be a 16mm earth?
yes look at this table
SWA
Sorry never copied, there is a table you can refer to unfortunately I can't copy it, try again
file:///C:/Users/Pete/Desktop/Resources/SWA%20CPC.pdf
No no
Has it worked this time
file:///C:/Users/Pete/Desktop/Resources/swa-as-the-cpc.html
Try the 'Upload a File' option near 'Post Reply' button mate.. That might work
Chris sorry can't copy and paste my table try Google SWA as the cpc should come up with some thing.
Reply to Swa sheath size too small in the UK Electrical Forum area at ElectriciansForums.net
Why would the RCD fail … yes it can happen but then it may not. Without it you have no protection on the TT System
4K
Sounds more positive.
