Swa size | on ElectriciansForums
Discuss Swa size in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
Friend of mine is having a feed to his shed.
Wants 5 sockets and some basic lighting. I think 40A would be sufficient.
its 20ft away max.
what size swa would you recommend?
Would 16mm be ok?
The regs are there to help you out in this situation. Have a look at the current carrying capacities of SWA, installation method comes into play and also volt drop. I'd say that if its 20feet max then your not going to notice much volt drop but just to 'cross the Ts and dot the i's'.
its 20ft away max.
Would 16mm be ok?
Could you tell us what calculations you did to get arrive at 40A and 16mm, then we will be able to help you understand where your calculations may be going a bit wonky.
If you are a trainee as mentioned above then it would be best to ask your questions in the trainee section where you won't get any of the **** taking which has occurred in this thread.
To be honest you would be better off ask the electrician Ho is mentoring you through your apprenticeship for help, and also to advise you on when you are ready to start doing little jobs like this on your own.
The current carrying capacity tables are no use until a figure of In which has been adjusted according to correction factors has Ben established
Sorry for late reply. Battery died
I should have explained. i was given this information from a friend of mine who is doing the job, I'm just helping and watching really. I was just thinking out loud and wanted to know what size swa would be needed. He probably knows already but I wanted to see if I could figure it out myself.
i guess I would need more information to really work it out
If he only 'probably knows' he shouldn't be doing the job.
Reply to Swa size in the UK Electrical Forum area at ElectriciansForums.net
If you think that's bad you should try manually winding out the safety curtain in a theatre.
davesparks
You need a galvanic isolator in the earth coming from the shore power. If using lithium batteries you will probably need a dc-dc charger to...
davesparks
