Discuss Swa size in the UK Electrical Forum area at ElectriciansForums.net
You are spot on. I was only joking. In the real world a 6mm swa will suffice for a long long long time .Come on the OP is a trainee, the posts above are hardly productive ?
wow .you are spot on. I was only joking. In the real world a 6mm swa will suffice for a long long long time .
Truth be told a 2.5 wouldn't come to any harm either. There is never likely to be any substained load on this cable
I thought op had already worked out In as they stated the value of 40amps
It's a shed with '5 sockets in and some basic lighting', op didn't state they were going to be running a machine shop out of it. I understand where your coming from. Obviously if he would have said what he was intending on using the shed for and then listed in detail every piece of equipment that his friend would be using then I would have been happy to point him in the right direction as to what size cable he should be installing. But instead I pointed out that maybe using the In value that he imo had possibly sat and worked out (seeing as it's only 5 sockets I'd have said he had no intention of pulling 40amps) he could look at the tables in the regs and then come to a conclusion for himself and then possibly come back and show how he come to his decision and then we could help out from there.The chances of the application of all factors resulting in a value of 40A is pretty unlikely don't you think?
i guess I would need more information to really work it out
You learn something everyday. Are you telling me 6 mill swa won't carry this load for 20 metres?wow .
LikewiseCome on the OP is a trainee, the posts above are hardly productive ?
I didn't mean to cause all this bother :-/
like i said my friend basically asked me if I wanted to tag along for some experience. I have no doubt he has worked it out. But the one thing he didn't tell me was the size of the swa cable and it got me thinking which is why I asked.
ultimatly i I don't have enough information to work it out so I'll have to ask him
He's an electrician. I will ask him when I see him.
apologies, I didn't mean to be a noisance. I just think about all these things a lot and it just crossed my mind about the size of swa cable so thought I'd ask.
thanks for the words of advice. I already have access to the trainee section. This should have been posted in there
Mate you aint being a nuisance, honest, good luck and ask one of the Moderators for Trainee status. you'll learn nothing if you don't ask.
Reply to Swa size in the UK Electrical Forum area at ElectriciansForums.net
