B
BillyH
What options do i have for terminating a 16mm 3 core swa into a plastic consumer unit?
Discuss SWA submain into plastic consumer unit? in the Australia area at ElectriciansForums.net
In the context of mechanical or earthing ?
are you using the 3rd core as cpc? if so, then the armour only needs earthing at the supply end.
So i would'nt need to use a gland. I could just expose the conductors and connect as per mains tails
Try and fit a conduit box to the consumer unit,it can be fixed securely reducing strain on the cons unit and allow the termination of the Swa to be done
Reply to SWA submain into plastic consumer unit? in the Australia area at ElectriciansForums.net
