SWA, T&E or tails?? | Page 6 | on ElectriciansForums
Guest viewing is limited
Discuss SWA, T&E or tails?? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening all..
I am currently doing my first full rewire. The customer is having the wall knocked down with the meter/cutout and CU on it. the plan was to move the CU under the stairs and get DNO to move the supply to the same place. They have said they cannot move the cutout to where the CU will be. The approx length from cutout to CU will now be around 8m so I need to add a fused switch. My questions are about which type of cable to use:
1. I could use 2 core 25mm SWA (seperate 16mm earth) but I am unsure of how easy this is to bend through the route? It will be going straight up from the meter box and then 90degress into the house wall entering directly under the first floor floorboards. What is the best way to get it through the wall without putting too much strain on it (with regards bending angle)?
2. BS7671 states 25mm to be used, however I am fusing down to 80A, could I not use 16mm SWA as CCC is 87A?
3. Could I use tails as at no point will the tails be buried in the wall. They will be going directly under the floor boards from outside the house (suitable protected outside) and then down from the ceiling directly behind the new CU (there will be a cavity behind new CU as I will bring out from the wall). Do they need to be protected if they are not getting buried in the wall?
4. Which is easier to move around/use T&E (16mm or 25mm), SWA (16mm or 25mm) or tails?
5. Which is the best fused switch to use? KMF, wylex metal? Can I gland SWA into a KMF or does it need an adaptable box?
Cheers chaps:biggrin:
Reply to SWA, T&E or tails?? in the UK Electrical Forum area at ElectriciansForums.net
totally agree
Recommended Sponsor News
Hi everyone,
HappyHippyDad
Supporter
Gloucestershire
United Kingdom
SWA, T&E or tails??
