SWA to garden studio
Hello- I am installing an SWA cable down a garden to a shed which is going to be used as a recording studio. It will not have enormous current requirements, probably along the lines of a normal house with ring mains etc. plus maybe an airconditioner.
Would a 31 amp rated 2 core + earth SWA be OK for this? Do you recommend any cable as being better than the rest, interms of workabilty, durability etc?
Initally it will be terminated until the building is erected- what's the orthodox way to termminate an SWA while the building gets built? The build needs to run the cable through his conduit asap so the sparks can include it in the main CU for the house.
I need about 50 metres. Thinking of burying it ( which I think can be done directly? ) but may look at a catenery also.
Thanks for any advice.
N
My extremely limited understanding of specialist audio visual equipment would lead me to suggest that you may need an electrician with a good understanding of electrical noise and what it can do to AV equipment.
Trusty Crow,
derek,
