SWA - too short!!!!!!!!!!!!!!!!! | Page 2 | on ElectriciansForums
Discuss SWA - too short!!!!!!!!!!!!!!!!! in the UK Electrical Forum area at ElectriciansForums.net
England
been working on site today - came across someones bad calculations - there is 6mm swa in a ducting underground and it only comes out of the ducting at one end! i managed to dig down to the ducting and found the other end buried underground.
So what is the best way of connecting two pieces of swa in a ducting?? resin joints? or connectors in a connector box?
Resin joint in ducting.. Hmm sounds like a dodgy situation. Ducting fills up with water, the joint would need to be 150% perfect or its going to fail in a year or three's time.
I don't mind burying resin SWA joints as they are drained, mostly. But this has the potential to be submerged.
I agree with the others, pull in new cable.
PS, how you going to access the joint site if the end is in the duct?
Reply to SWA - too short!!!!!!!!!!!!!!!!! in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
