SWA - too short!!!!!!!!!!!!!!!!! | Page 3 | on ElectriciansForums
Discuss SWA - too short!!!!!!!!!!!!!!!!! in the UK Electrical Forum area at ElectriciansForums.net
England
been working on site today - came across someones bad calculations - there is 6mm swa in a ducting underground and it only comes out of the ducting at one end! i managed to dig down to the ducting and found the other end buried underground.
So what is the best way of connecting two pieces of swa in a ducting?? resin joints? or connectors in a connector box?
I hate underground joints I always have a feeling that one day it'll let you down
Not sure of the age of the joints under the front gardens of my street. They joined the original pilc cables at some point and replaced with a short section of concentric into the meter box. Possibly late 70's early 80's ?
Mine and both my next door neighbours all failed within 18 months of each other though. Quite well coordinated failure I thought.
There have been lots of failed joints of that sort of age where houses are teed off from the main under the pavement.
Install one of these and make the joint in there.
[ElectriciansForums.net] SWA - too short!!!!!!!!!!!!!!!!!
Reply to SWA - too short!!!!!!!!!!!!!!!!! in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
