Switch Wiring Problem | on ElectriciansForums
Discuss Switch Wiring Problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
MidsomerDave
Can anyone help, please?
I have lived here in Portugal for 8 years and understand that following the wiring colour code changes that happened in the UK during 2004/2006 the codes for both countries are the same for fixed mono phase installations (Brown, Blue and Green/Yellow). I´m not an electrician but would like to know what the OFFICIAL way is to wire a domestic switch. What colour should the wire be on the switched side? I have looked at many sites and the answers vary between continuing using the brown as far as the light, using the blue but with brown sleeving at each end, and one suggested using a separate colour altogether! Can anyone clear this up please? Sorry if this seems a bit trivial for you experts, but no-one here seems to know!! Thanks, Dave.
Hi Dave,
Here in the uk, we use standard twin and earth (brown and blue), for the circuits and the switch drops.
With the switch drops, the switched line return to the fitting is sleeved brown at both ends, switch and fitting.
Only reason being is that you will always have a roll of 1 or 1.5mm on the go.
Twin brown is available but is very rarely used, if at all.
Hi Dave,
hi jason before we changed to the brown + blue i worked in gallway we used
twin brown and earth for switch drops i have never seen it in the uk
where can you get it here ?
I worked in Ireland about 5 years ago.
On two-way lighting, the sparks used a twin-brown for the strappers and a 1.5 double insulated single core for the common. Took me aback when I first saw it, but it's the same as using a three core & earth I suppose.
Hi Dave,
Speak for yourself my friend! I have always used twin brown,and twin red way back when.But then we wouldn't use 1mm either.Each to their own.
agree, we use brown and blue t&e and sleeve the blue with brown sleeving, why we ever changed our colours anyway was stupid as what could be more clearer than Red/Yellow/Blue /Black, why didn,t they change to our colours in Europe?
I think that using 1mm is ok as is 1.5 all down to the loads you want out of it, if like us we only use 1.5, we do that purely because sometimes we have done installs and yrs down the line they want extra,s then we have a little spare and dosn,t mess the decor up. Its like using shallow swich boxes against 1" deep ones, we always use the 1" ones then sometimes a dimmer sw or something will fit. does,nt make it wrong or right just preference
Any reason why not?
No good ones,mainly habit,I guess. I seem to remember our tech teacher steering us away from using 1.0mm.I think when using 1.0mm the maximum circuit length on a type B breaker is about 35m,whereas with 1.5 it is over 50m(could be rubbish,going from memory here)And the fear was someone coming along later and extending the circuit. Other possible reason was that at that time there was less problems if your installation design was to the on site guide and I think there used not to be any tables
for 1.0mm except for use with rewireable fuses which we were trying to get away from. Other possible reasons 1.0mm did not have a basec accredation. But mainly I suppose its got to do more with specifiers of council house work specifying 1.5mm minimum and also most of my work would be of a commercial nature.;)
Agree t/e sleeve n brown unless your using the dreded trunking then can use brown singles.
Any reason why not?
hi there
may i draw your attention to appendix 7 of the big red book page 342
introduction the bit about cable identification
to mee that says ok we have harmonized colours but anything will do provided it is identified
think this is to cover older installations stuff from other countries and sparkies who run out of twin red cable lol
opinions
please:confused:
Reply to Switch Wiring Problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Apart from ripcord and maybe a speciality flat elevator type ribbon cable I've also never seen a cable with two identical blue wires. I highly...
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
