Switch Wiring Problem | Page 2 | on ElectriciansForums
Discuss Switch Wiring Problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for that everyone...seems the general consensus is that brown sleeving on a switched blue wire is acceptable then. Maybe it´s a matter of preference, just as long as it´s not WRONG! Just for information all domestic lighting circuits here in Portugal are 1.5mm. Thanks again. Dave.
i have always used 1.5 buider has supplied 1.0 i used it for switch drops and sent him
back for 1.5 this is just the way it was done from day one however if you read the manufacturers instructions on elv tranformers 1.5 cable min
so 1.0 would not comply
Reply to Switch Wiring Problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Apart from ripcord and maybe a speciality flat elevator type ribbon cable I've also never seen a cable with two identical blue wires. I highly...
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
