Switched live connected to neutral on lamp | on ElectriciansForums
  • If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
You're viewing the old forum category for electricians jobs. That's fine and you can reply to threads and contact the person who posted the jobs etc too. But for new electricians jobs post to the new job forums instead; Electricians Available for Work Post Here, People seeking domestic electricians post here, People seeking Commercial or Industrial Electricians post here
Discuss Switched live connected to neutral on lamp in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Beeg
UK
Hi all,
Newbie here after some advice.
I’m in the process of replacing my landing light and when disconnecting the old one I noticed that the SW live was connected to neutral on the lamp and the circuit neutrals connected to live on the lamp.
I am aware that normally the SW live would go to live on the lamp and all the neutrals would be connected together. However the lamp has worked fine for the 3 years we’ve been in the house. Just wondering if I should change the connections? Or could it be that the wrong cable has been identified for SW live?
It’s 2 way lighting if that makes any difference.
Any advice greatly appreciated.
Ben
[ElectriciansForums.net] Switched live connected to neutral on lamp
It should not affect lamp operation although some led lamps can be polarity biased. Yes you should reconnect it when you fit the new light but I have to say those block connectors are a poor means of connection especially if they are shoved up into the ceiling cavity as is poses a real fire risk.
Do you have the equipment to test which is the actual switches live or not and know how to practice safe isolation? If yes to both it’s worth changing if incorrect as depending on the bulb holder type having reverse polarity exposes live parts for unwary fingers when changing a bulb. If no to one or more questions just be wary when changing a bulb and get someone qualified to assist.
Edit:- and what Westward10 said re the blocks too!
With all due respect to you and the guys that have answered your post, if you are that unsure of what you are doing, then I would recommend you employ the services of an Electrician, messing with something you know little about, can, and will be dangerous.
Whilst members of the forum try and help where we can, offering advice to a DIY er can prove hazardous, after all if advice is given, and not understood, what would you think? you think you are competent, but in reality you aren't, do yourself a favour and get a professional electrician in to help, it shouldn't cost more than an hours work and save you the heartache of wondering, about the work you have done.
Others may mock but my experience tells me you need some help.
Hi all,
Ben
Were are you located? someone local to you may may be able to help you out.
Thanks for all the advice guys. I understand how it should be wired up but just wanted to know whether there was any safety issues in it being connected as it was - thanks DJ Ovengloves for explanation of exposed parts being live when changing bulbs.
Westward, what do you use instead of the chocolate block connectors?
Thanks again
Beeg
I came across switched neutrals once as an apprentice in a school rewire job. Was told to cut down the pendants and save the lamp shades, big metal dome things... Was told the power was off, 'cos the lights were off... just cut through the flex and take down the pendants.
Can you see where I'm going with this yet?
Earth in the pendant flex too..... My first pair of pliers ruined.
Reply to Switched live connected to neutral on lamp in the Electricians Jobs area at ElectriciansForums.net
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
Electricians Jobs, Electricians Mate Jobs and Electrician Apprenticeships
Thanks for visiting ElectriciansForums.net, the worlds largest electrical and electricians community. This area of the website is for those who are looking for electricians jobs, electricians mate jobs, or electrical apprenticeship schemes. We have opened up our website to the world after being UK-only for more than 10 years. We now have jobs posted to the forum for domestic, industrial and commercial electrical work from all over the world. Anybody is welcome to register to our forum for free. You can post jobs you have going, or know of. And you can also post to the forum if you're looking for employment or recruitment. Full or part time. Just let us know the full details of the job you have on offer or are looking for and we'll do the rest.
Also note that we have tiling jobs, and plumbing work too.
