Switching non timer extraction fan | Page 2 | on ElectriciansForums
Discuss Switching non timer extraction fan in the UK Electrical Forum area at ElectriciansForums.net
Andover
Hi,
Can't seem to find anything in the regs but I have been asked to fit an extractor fan in a small cupboard containing some IT equipment which gets quite warm and it's just to dissipate heat out of the cupboard. My question is, as it's a fan without run on timer I am using T&E to power it and just wondering of its ok to use a standard 10 amp one way switch to isolate. Just wondering if I need to wire it so to isolate both line and neutral or whether it's ok to just isolate the line conductor as I don't seem to be able to source a double pole switch under 20 amps.
It's this one. [ElectriciansForums.net] Switching non timer extraction fan
It will be wired from the lighting circuit and she wants it to run 24/7 unless she decides to switch off. Still waiting for supplier to get fan so don't know yet if manufacturers state fusing or not. Will have to make that decision at the time. Don't suppose I could use a 20 amp switch fuse with 3 amp fuse to cover all bases.
Click (and CEF do their own make) do a 3 pole isolator with fuse you can use. Just don't use the S/L if not required.
Reply to Switching non timer extraction fan in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
