Switching non timer extraction fan | Page 3 | on ElectriciansForums
Discuss Switching non timer extraction fan in the UK Electrical Forum area at ElectriciansForums.net
Andover
Hi,
Can't seem to find anything in the regs but I have been asked to fit an extractor fan in a small cupboard containing some IT equipment which gets quite warm and it's just to dissipate heat out of the cupboard. My question is, as it's a fan without run on timer I am using T&E to power it and just wondering of its ok to use a standard 10 amp one way switch to isolate. Just wondering if I need to wire it so to isolate both line and neutral or whether it's ok to just isolate the line conductor as I don't seem to be able to source a double pole switch under 20 amps.
Looks good. What is the problem with using a stat and airflow?
Sorry, nothing. Everything that has been said I support. The unit is not designed to do what the customer wants i.e. its and intermittent fan. Also wiring a fan to a stat would be good as well as ensuring there is airflow into the cupboard.
Hope that clarifies what I was trying to say?
What about one of these 2 [ElectriciansForums.net] Switching non timer extraction fan[ElectriciansForums.net] Switching non timer extraction fan
Make sure you wire the stat to make rather than break on temperature rise - the opposite to a central heating thermostat.
What stat would you recommend for this job - I need to do the same thing in my attic room, have wired ready but don't know much about thermostats. The changeover contacts - are they possible to reverse to make not break on all stats. Thanks
Sent from my iPhone using Tapatalk
This is the one I've been looking at.
Not sure how good it is but downloaded the data sheet and it shows how to wire it for both heating and cooling.
Hope that helps.
Thanks sparky1508 - the changeover contacts is the relevant bit.
Sent from my iPad using Tapatalk
Reply to Switching non timer extraction fan in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
Thank you. We do have a window. Do you think my idea (even if is adds complexity) is workable? Nothing fundamentally wrong that I am missing?
