Guest viewing limit reached
I've had a couple of requests for extensions to systems (7KW-9KW) we installed over the last few years. The DNO have given permission but I haven't a clue how to register the extension. I cannot see anything about extensions when submitting a couple on installations this morning. Are they registered as a new installations?
TIA.
MCS Register it as a new system, it's the FiT provider that will pick up it's on the same MPAN, - make sure they don't misband it though, some are known to..
Thanks Ted. They do have an epc. But..........................................I've done a new install today and the epc, which should have been done earlier in the week is not getting done now until Wednesday. Will that be a problem?
NEW installs the epc has be done before applying for FiT.
Extensions the EPC must be dated NOT Later than the date of commissioning - it can be the same date (who said commission in the morning epc in the afternoon :) )
If they already have an EPC of D or better then there is no problem. For an extension to get the higher rate the EPC must be dated on or before the commissioning date.
good point... got a 52kWp extension going in shortly, that could have been an expensive thing to get wrong.
this sort of thing is a complete farce.
Cambridgeshire
Website
http://www.solarsavings.co.uk
System extension
Green Lounge (Access Only)
Thread Tags
solarsavings,
Gavin A,
