Tail light wiring help needed please - Panigale 1199 S | on ElectriciansForums
Discuss Tail light wiring help needed please - Panigale 1199 S in the Auto Electrician Forum area at ElectriciansForums.net
Hello all,
I have a tail light for a '12 Ducati Panigale 1199 S, that I can't get working properly. The brake light / daytime running lights work fine through the factory connector. The turn signals are the problem, they do not work independently - they flash like hazard lights.
The tail light only has the 'hot' wire for each blinker (no ground) and comes with a resistor to be installed as well. I've added a summary below of the wires shown in the attached picture. Any help would be greatly appreciated.
  • Red arrows indicate the turn signal wires from the new tail light (hot only)
    Green arrows indicate factory turn signal wires (hot / ground)
    [*]Black arrow indicates the resistor that should be wired in as well.
Thank you kindly
  • [ElectriciansForums.net] Tail light wiring help needed please - Panigale 1199 S
Hi
Did you fix your lights? Would love to see a photo of your bike!
Reply to Tail light wiring help needed please - Panigale 1199 S in the Auto Electrician Forum area at ElectriciansForums.net
Thanks a lot FG; Thanks for that solution, I was looking along the same direction and yesterday ordered two 5 pin 12v 40A relays from Amazon and...
  • camperVanGuy101
  • Australia
  • 2
  • 751
