50k for six houses does sound lumpy.
how busy are you this evening Lee??!!...
6x PLOTS AS BELOW in chrome:
I came in at 52k inc VAT- NEW BUILDS IN SURREY
PLOT 1 GROUND FLOOR
Porch
1x wired doorbell+door chime inside hallway
1x fire rated IP65 7w LED down-light+ recessed PIR sensor
4x external wall lights+ 1x 1gang light switch inside -allowed for ÂŁ20.00 per fitting
Hallway
6x fire rated fixed 7w LED down-lights +3x 1gang light switches
1x mains powered battery backup optical smoke detector (interlinked throughout house)
1x d.socket
Cloaks
2x fire rated fixed 7w LED down-lights +1x 1gang light switch outside door
1x 100mm extractor fan+isolator switch outside door- builder to provide hole/ducting
Utility
2x d.socket
Living
1x pendant light+1x 1gang light switch
5x d.sockets
1x BT phone socket
1x TV socket
Study
3x d.sockets
Services Cupboard
1x fire rated fixed 7w LED down-lights +1x ceiling recessed PIR sensor
1x metal 10way Dual RCD consumer unit+ water/gas bonding
Dining/Family
2x d.sockets
1x BT phone socket
1x TV socket
Kitchen
6x fire rated fixed 7w LED down-lights +1x 1gang light switch
3x low profile LED UCL
1x mains powered battery backup heat detector (interlinked throughout house)
6x d.sockets (general use)
2x 20a oven circuit+ grid isolator
5x s.socket + grid isolator
1x external IP65 d.socket
PLOT 1 1ST FLOOR
Landing
5x fire rated fixed 7w LED down-lights +2x 1gang light switches
1x d.socket
Bathroom
5x fire rated IP65 7w LED down-lights +1x 1gang light switch outside door
1x shaver socket
Bedroom 1
3x d.sockets
1x BT phone socket
1x TV socket
2x fire rated fixed 7w LED down-lights +2x ceiling recessed PIR sensor inside wardrobes
En-Suite
2x fire rated IP65 7w LED down-lights +1x 1gang light switch outside door
1x shaver socket
Bedroom 2
3x d.sockets
1x BT phone socket
1x TV socket
Bedroom 3
3x d.sockets
HWC Cupboard
1x d.socket
1x 13amp spur for 3kw immersion heater
Dressing/ Bedroom 4
3x d.sockets
OTHER
6x 100a metal switch fused isolator+20meters of 25mm 3core SWA sub main+ additional ext meter box
1x 13amp switch for spur only for combo boiler in 6x plots
1x Nest Smart Thermostat’s for Combi Boiler in 6x plots
7x Texecom Premier Fully featured Burglar Alarm system with 4x PIR’s, 1x DC and chrome keypad
1x pendant light+1x 1gang light switch + 1x d.socket in 6x plot lofts
2x external bollard lights per 6x plots -allowed for ÂŁ100 per bollard
-all trenches/ducting to be provided by client
1x metal 5way landlord consumer unit
6x communal external bollard lights- allowed for ÂŁ100 per bollard
1x 13amp switch fuse spur only for electric gate]
