Taking on 9 flats | on ElectriciansForums
Discuss Taking on 9 flats in the Commercial Electrical Advice area at ElectriciansForums.net
IPA76
South London
Hi
This is my first post and looking for some advice. I have been offered the job of wiring 9 new 2 bed flats just about to be built. I have not taken on anything this big before and not sure how many extra Electricians I will need to keep up with the builders. Anyone done this level of work? As I normally work on my own.
Depends, you and two others would be my best be especially during 1st fix, what with concrete pours etc.
Biggest piece of advise I can give is make sure everything is in writing and don't do any extras without agreement signed by your client before you do them.
Got caught out by a builder who came across as genuine and pally alway through job on 12 apartments and 2 penthouses then stung us for nearly 15k at the end. He got caught by developer then took all sub contractors for what he could.
Don't worry not all like it. Just be cautious. Our own fault for not having enough in writing.
Done many flats , new builds and mill conversions over the years
THE flats them selves are easy to control price wise and timescale wise ( even give out a price )
It’s the landlord areas that can usually drag on , and could cost you money
Door entry , fire alarm , lighting , car park lighting , sky tv , B.T , sub mains rooms , lifts
As said in another thread depends how organised your builder is
Don't forget you will need LSF cable for public areas.
Plant room can take time if you've got all your mains supplied from a ryfield board and making sure it's neat when you've finished. Don't seeing messy plant rooms.
Planning your routes so you don't need rcd protection on your supply cable to the flats.
Many thanks for all your advice, I will make sure I get it all in writing and will spend a good amount of time on the paperwork. This job will include data and sky and under ground parking. Its not been firmed up yet but its in the region of ÂŁ110K. When I know more I will come back, and thanks again.
Get everything in writing signed and checked.
It annoys the hell out of me when people get trades in and then try to screw them over.
also a job that size is a good chance to take an apprentice or part qualified /electricians mate on looking for experience. pay them a fair wage and you can get a extra pair of hands to help out when you aren't in need of fully qualified electricians to assist at certain points of the work.
These sort of jobs are bread and butter for us...They're not difficult. Organisation is key so you don't loose time pottering around trying to make up a days work etc. The distribution side of things will be a BNO installation so make sure this is priced spot on as the gear and labour can be lumpy. BT, TV, door entry, fire alarm etc are all easy to price.
I got told by a builder that 50k was too expensive for 6x 3bed houses in Surrey -with alarms, nests, downlights and in chrome. various bollard lights around the land and a sub main from front meter box to rear c/u
150k for 9flats- GRAB IT!
50k for six houses does sound lumpy.
how busy are you this evening Lee??!!...
6x PLOTS AS BELOW in chrome:
I came in at 52k inc VAT- NEW BUILDS IN SURREY
PLOT 1 GROUND FLOOR
Porch
1x wired doorbell+door chime inside hallway
1x fire rated IP65 7w LED down-light+ recessed PIR sensor
4x external wall lights+ 1x 1gang light switch inside -allowed for ÂŁ20.00 per fitting
Hallway
6x fire rated fixed 7w LED down-lights +3x 1gang light switches
1x mains powered battery backup optical smoke detector (interlinked throughout house)
1x d.socket
Cloaks
2x fire rated fixed 7w LED down-lights +1x 1gang light switch outside door
1x 100mm extractor fan+isolator switch outside door- builder to provide hole/ducting
Utility
2x d.socket
Living
1x pendant light+1x 1gang light switch
5x d.sockets
1x BT phone socket
1x TV socket
Study
3x d.sockets
Services Cupboard
1x fire rated fixed 7w LED down-lights +1x ceiling recessed PIR sensor
1x metal 10way Dual RCD consumer unit+ water/gas bonding
Dining/Family
2x d.sockets
1x BT phone socket
1x TV socket
Kitchen
6x fire rated fixed 7w LED down-lights +1x 1gang light switch
3x low profile LED UCL
1x mains powered battery backup heat detector (interlinked throughout house)
6x d.sockets (general use)
2x 20a oven circuit+ grid isolator
5x s.socket + grid isolator
1x external IP65 d.socket
PLOT 1 1ST FLOOR
Landing
5x fire rated fixed 7w LED down-lights +2x 1gang light switches
1x d.socket
Bathroom
5x fire rated IP65 7w LED down-lights +1x 1gang light switch outside door
1x shaver socket
Bedroom 1
3x d.sockets
1x BT phone socket
1x TV socket
2x fire rated fixed 7w LED down-lights +2x ceiling recessed PIR sensor inside wardrobes
En-Suite
2x fire rated IP65 7w LED down-lights +1x 1gang light switch outside door
1x shaver socket
Bedroom 2
3x d.sockets
1x BT phone socket
1x TV socket
Bedroom 3
3x d.sockets
HWC Cupboard
1x d.socket
1x 13amp spur for 3kw immersion heater
Dressing/ Bedroom 4
3x d.sockets
OTHER
6x 100a metal switch fused isolator+20meters of 25mm 3core SWA sub main+ additional ext meter box
1x 13amp switch for spur only for combo boiler in 6x plots
1x Nest Smart Thermostat’s for Combi Boiler in 6x plots
7x Texecom Premier Fully featured Burglar Alarm system with 4x PIR’s, 1x DC and chrome keypad
1x pendant light+1x 1gang light switch + 1x d.socket in 6x plot lofts
2x external bollard lights per 6x plots -allowed for ÂŁ100 per bollard
-all trenches/ducting to be provided by client
1x metal 5way landlord consumer unit
6x communal external bollard lights- allowed for ÂŁ100 per bollard
1x 13amp switch fuse spur only for electric gate]
Reply to Taking on 9 flats in the Commercial Electrical Advice area at ElectriciansForums.net
S
Tiling On Concrete Blockwork Outdoors hi all just been offered a job tiling an outdoor bar ...the bars walls are made from concrete block (not...
Samb213
S
Your electrician shouldn't be doing anything to the cutout, that is the property of the electricity supplier and they make the connections to it...
davesparks
