Solar King,
As you correctly state, with tighter margins, economic modelling is now even more important in demonstrating the viability of an installation.
The Economic Efficiency Calculator in PV*SOL is based on the VDI 6025 Economic Standard and is a very flexible and powerful tool for economic analysis. If you wish to calculate returns from actual use of the electricity generated or to create a ‘deeming’ scenario then it is necessary to define a consumption load profile first i.e. select ‘net metering’ rather than ‘full feed in’
You will then have the option of selecting the British/Italian feed in tariff on opening the calculator and here you can define both a generation amount and an export amount. Alternatively, if you prefer to use a deeming approach, you can simply add half of the export amount to the generation amount and then enter zero for the feed in payment.
The results generated in the PV*SOL Economic Efficiency Calculator gives the Net Present Value (NPV) – the sum of the discounted cash flows of the scheme i.e. the sum of all terms, R[SUB]t[/SUB]/(1+i)[SUP]t [/SUP],where t is the time of the cash flow, i is the discount rate (the rate of return that could be earned on an investment in the financial markets with similar risk); the opportunity cost of the capital, R[SUB]t[/SUB] is the net cash flow at time t. The Internal Rate of Return (IRR) is also calculated – referred to in PV*SOL as ‘Yield’ i.e. the annualized effective compounded return rate or rate of return that makes the net NPV of all cash flows (both positive and negative) from a particular investment equal to zero i.e. Given the (period, cash flow) pairs n,C[SUB]n[/SUB]: NPV = ∑(C[SUB]n[/SUB]/(1+r)[SUP]n[/SUP] from n=0 to N; where n is a positive integer, N is the total number of periods, NPV is the net present value and r is the internal rate of return.
Explanations for all of these terms are available in the Help menu- accessed by pressing F1 at any time.
While it is true that such concepts are not beyond the understanding of the layperson, our experience thus far has shown that few attendees to our training courses are familiar with these concepts. To fully explain this approach to financial modelling would take a considerable amount of additional time and would not fulfil the remit of the training - which is to show how the program works. By the same token, we do not go into the details of the photovoltaic effect (which of course underpins the whole technology) i.e. the concept of a p-n junction and how the carrier flows under equilibrium, short circuit and open-circuit conditions; nor do we examine the theory behind inverter MPP matching and the various algorithms used to ascertain the current which the inverter should draw form the PV array.
We recognise that each individual attendee has a different level of cognisance of the concepts listed above and the course is subsequently tailored to suit this wide range of experience and understanding. We also recommend books and other sources of information to augment the training. Background reading on this and any other taught course is essential to begin to grasp any subject in its entirety.
I will be happy to send you our guide to using the PV*SOL Economic Efficiency Calculator which explains in a little more detail the answer to your tariff query and will hopefully explain to you in clear terms how you can achieve the results you require. Please send an email to
[email protected] and we will email this document to you.
