Tell us about your faults! | Page 76 | on ElectriciansForums
Discuss Tell us about your faults! in the Australia area at ElectriciansForums.net
K
kung
Hi ALL
Just thought id put this one up for all those faults we find.
heres one to kick it off !
Domestic RCD tripped and wouldnt reset cause was a blown low energy light bulb.:D
There you go now for yours !
Come on trev, we know that black isnt the neutral anymore :59:
tell that to last retired electrician who's work i had to put right!!!!!!!!!!!!!!!!! brown black grey blue mm black looks like neutral ahh thats it red yelow blue!!!!!!!! we all new it would happen and lucky me had 25amps up the pipe line !!
moral of the story dont take nothing for granted
Re: Tell us about your faults !
I knew customer needed a 3ph socket installing, but he said he had already promised the job to someone else. Six weeks later, it finally got installed. I had a quick shufty today because have not seen the inside of one of these before, and noticed the interesting choice of earth link between the isolator switch above the unit and the socket itself.
[ElectriciansForums.net] Tell us about your faults!
Just trawled throught the 1,100+ posts in this rogue's gallery with great amusement. But the one above, from 2 years ago, stands out because everyone comments on the dodgy CPC wiring. But nobody seems to have seen anything at all untoward about this TP&N commando having being wired without a neutral!
:nono:
I'll put my hands up for that one, Shunter, well spotted. It was my original post and I never clocked about the missing neutral. I do know that the only 3ph equipment they plug in (a steam cleaner) does not need a neutral, but that is no excuse. It also means that the steam cleaner has the wrong plug on.
I had no earth at a double socket once, when checking my values with my MFT scratching my head, i was completely baffled as I had run the new circuit.
Turned out to be a missing peice of the earth bar on the Click Polar range socket i used.
My fault for not checking it visually hah
Reply to Tell us about your faults! in the Australia area at ElectriciansForums.net
This is a baffling fault I've been fighting with for a couple of weeks now, so I wondered if another set of eyes will help. I installed an EV...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
