Temp extension cable for welder | on ElectriciansForums
Discuss Temp extension cable for welder in the UK Electrical Forum area at ElectriciansForums.net
WS151BZ
I have a 80m run to the bottom of my garden is it practical to run 2 extension cables down the garden and join them together with a make shift link lead both outputs joined together into a single output socket. to allow better current load capability and hopefully less voltage drop to drive my 200a inverter welder, this is temp for a one off welding job
Thanks for any feedback
Practical it may, but not advisable, doubt if you would get many Volts out at the end with an 80m run
Any set up which leaves 2 plugs connected together will mean the pins remain live on the first one to be unplugged if the second one is still plugged in and so should never be done. If you happen to know anyone with a 6mm 32A cable (with cee form connectors) you could step up and run that and then step back down again. But might be easier to bring the welding closer to the supply or use gas.
What you would be making to do this would be an device commonly known as a widowmaker.
This information alone should be enough to tell you it is a pretty bad idea.
Your best options are to hire a welder generator or gas welding.
Reply to Temp extension cable for welder in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
