off the top of my head its something like 150mWhy was the 70mm opted for out of interest ? How long is the run ?
In that case it sounds like a horrendous design when taking installation and selectivity into account. I wouldn’t be feeding a distribution circuit that’s over 150 meters away using a mcb as it’s OCPD. I would be looking at either a fused switch, a switch fuse or an MCCB with selectivity being a major factor/consideration in the design.yeah that looks a good method, but the swa will be on an outgoing circuit, and going into a breaker, not the incomer , sorry. large cable due to lengthy run
basing it on 5 percent (other uses). gone larger cable, as the outgoing circuits on the far board may have large runs too, so ensuring those cables can be potentially smallerWhat %vd are you using.
Goldfish imitation in progress here ...This is a circuit from the board not the supply cable to it.
It is supplying a board but I think the issue is the source end, I think?The load side is connected to a cu unless ive misread it?
Reply to the thread, titled "terminating 70mm swa into 3ph board, best way?" which is posted in Commercial Electrical Advice on Electricians Forums.
