test and certifying... | on ElectriciansForums
Discuss test and certifying... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
London
i was just curious how much you would charge to t & c a house with about 10 circuits. On average...thanks
Are you talking about a PIR inspection? Or do you mean testing the circuits from the CU and putting readings on an EIC? Because you're not really meant to do that!
No, you've misunderstood. Ive had an NIC bloke quote me a periodic and certify the electrics are ok in my house. How much would u charge 4 it?
Reply to test and certifying... in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would have thought they'd have a switch to flick on and off to engage an override. Not on each PIR but an actual light switch
Apart from ripcord and maybe a speciality flat elevator type ribbon cable I've also never seen a cable with two identical blue wires. I highly...
