tester trouble | Page 2 | on ElectriciansForums
Discuss tester trouble in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I've got a fluke 1652 and i also have problems with continity testing. I had a NICIEC inspection about a month ago and the inspector said he finds alot of problems with fluke. I had my tester re-calibrated and new batteries put in but can still get dodgy readings. You might have a lead problem but i've found that if you clamp the conductors between the flat bit on the lead and the teeth on the croc you'll have a bit more joy. Im saving for a megger set.
Reply to tester trouble in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Very technical :D
