Testing and Inspection Over Current Protection | on ElectriciansForums
Discuss Testing and Inspection Over Current Protection in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
John-
Uk
Hi. Silly Question, as a tester / inspector of an installation. How do i confirm that overload protection is satisfied for an existing circuit, or is it just assumed as long as Coordination (p89 18th Regs) is satisfied and the protective devices is of a EN BS device? Practically, how do i confirm this though? Where do i find 'I2' details for OCPDs?
John
Yes, fuses are following the same basic idea as MCB.
For rewirable fuses (BS3036) there is a larger margin between the fuse rating and the capacity of the wiring (see reg 433.1.202) but for enclosed fuses like BS88, etc, you treat them as for MCB ratings.
The bigger issue with rewirable fuses is if some muppet has used the wrong wire in the past, sometimes to "stop it blowing" without realising what danger it presents. Table 533.1 (p159 of 18th regs) has the nominal diameters of wire but you would need calipers or similar to check that in practice.
For 3036 fuses you apply the correction factor 0.725.
for example a cable Protected by a 15 amp 3036 fuse would need to carry 20 amps , if overload protection was required.
@pc1966 explains it nicely.
Reply to Testing and Inspection Over Current Protection in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
