This is a difficult one, if you do to much testing you arein danger of wasting your time, but I follow the best practice guide andexplain to customers what I am doing.
My first approach is to try and get the customer to have aPIR done, they genrally don’t want one because of the extra cost, so I thenexplain the consequences of not doing one but insist on doing the doing thefollowing. Not many refuse this testing. It does not take long.
• making enquires with the user as to whether there are anyknown defects, faults or damage,
• an internal visual inspection of the existing consumerunit to determine, amongst other things, the type and condition of the wiringsystem used for the installation,
• an external visual inspection of other readily accessibleparts of the installation,
• a measurement of the external earth fault loop impedance,Ze,
• a test of circuit protective conductor continuity at theend of each final circuit, and
• an insulation resistance measurement of the wholeinstallation at the consumer unit, between the live conductors connectedtogether and the protective conductors.
Most people tend to get at least 2 quotes for doing thissort of work, and I always make the point of asking if the “other electrician”did any testing and from my experience most don’t. So when I bring out the bestpractice guide and show them what it says I get some brownie points, and moreoften than not I get the work, without being the cheapest.
I also always give a contract stating that remedialworks will be at the customers cost.
