Testing-Installation & periodic certificates | on ElectriciansForums
Discuss Testing-Installation & periodic certificates in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
simbin
I've been asked to test an existing installation which isn't a problem-the problem is can a certificate be issued if all is fine BUT the consumer unit is to the 16th edition? It could turn into an expensive job to make everything RCD protected! The same question but in relation to periodic inspection certificates.....:confused:
The PIR has a section where you report non compliance with the regulations whereby you have 4 options for remedial action to be taken; 1 being the most serious (basically a major issue has been discovered that requires immediate attention) & 4 is just non compliance with no action to be taken.
Really to effectively undertake testing, especially PIR's, you need 2391 but most of all experience. You are signing your name to a document that could come back to bite you if you are not carefull.
I've got 2391 but lacking experience!! When does a non compliance become a code 2,3 or 4??!! At some point all consumer units must be upto 17th edition standard...There is plenty of grey area's surrounding the change from 16th to 17th edition regs!
I am trying to work out if you are testing an install for someone else as a EIC or testing an installation as a PIR, if it is as a PIR then it doesn't matter what is installed, you are only telling the client what they have installed with recommendations, its up to them what they do
with ELECSA the official line is this...
No RCD protection to socket circuits - Code 2
No RCD protection to lighting etc... Code 4
The big grey area with PIR's is how far back in the regs is deemed unsafe?? At the present time, is a house built 2 years ago and wired to the latest 16th edition regs deemed as unsafe?? The answer is, of course not and therefore any areas you find that do not comply with current 17th edition regs would be marked down as a code 4... However, if you go to an installation that was wired in accordance to 15th edition regs is it still unsafe? even if all testing shows its ok. I've asked this question many times to college lecturers and ELECSA inspectors and non of them seem to give the same answer.
At the end of the day, its the responsibility of the person carrying out the inspection, if you feel the instalaltion is unsafe, report it as such.
Confused as to why different circuits need a different code! If the install conformed to 16th, then its a code 4, simples.
Steve.
Its pretty much down to the inspectors descretion, I wouls also go with the same difference for lighting and sockets due to the ability to plug an extension lead in for out doors use. This makes it potentially more unsafe than a static lighting circuit.................
IMHO i would code 1 sockets that can be used outside equipotential zone as a 1 but i agree others a 2.
As its a PIR you are highlighting faults and then putting reccomendations the client doesnt have to do anything about it but as long as you have told him your covered.
Who at elecsa has said this? have you seen it wrote down anywhere?.., I would of thought that No RCD protection would of been a code 4, it doesnt comply with 17th.
Doesnt make the install unsafe
So are the majority of you giving a 3036 board a code 2? and telling the customer that they need a new Dual RCD board before they get a satisfactory?
just out of curiosity, how much are people charging for pir's? i have been in the game ten years, and having gone on my own this year, ive got 6 two bed flats to do in january, which were converted about 10 years ago.
Reply to Testing-Installation & periodic certificates in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
