Testing Ze when you cannot disconnect the bonding? | Page 2 | on ElectriciansForums
Discuss Testing Ze when you cannot disconnect the bonding? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
The other option, although not ideal, is to test and record that Ze was taken with parallel paths in place. This happens more so in commercial and industrial settings where the supply cannot be shutdown for financial reasons.
That is not Ze, that is a Zs measurement.
[automerge]1592940600[/automerge]
That's what I would have expected to be done. Although would it really be necessary to connect all three of the original wires that now just go back to the cut-out? Surely one would be enough and the other two, now redundant, wires could be cut back flush.
Every time I have come across this it has dated back to the days when 6mm main bonding was installed so all 3 conductors are 6mm.
Now the conductor from the service cutout to the MET should be 16mm for a PME supply (which this is as per the label)
So if they are 6mm then all 3 would need to be connected to achieve the ideal 16mm CSA.
either by measurement or calculations.
If I remember from my college course many moons ago, you can also request the Ze figure from your local, friendly and ever helpful electricity supplier.
I've never tried it though. Anybody else had success with this?
They will give you their nominal design limits, which are usually also available from their websites (buried somewhere, if you look hard enough)
For example 100A TNS will normally be quoted as 0.8ohm
100A TNCS will normally be quoted as 0.35ohm for existing supplies or 0.25ohm for new supplies (this is true for UKPN at least, not sure if the others work to 0.25 now/yet)
Yes. Those (IIRC ) are the standard figures from DNO Engineering Recommendation P23/1 - which, I believe, is the origin of the 0.35 and 0.8 figures.
Remove the small circular plastic inserts you see and undo the screws with the T-Bar @7029 dave has illustrated. While you are at it, remove the bonding cables and insert them into an MET bar screwed somewhere convenient. Really speaking those bonds should never have been put in the DNO equipment but on a separate MET where the main earth is terminated.
Reply to Testing Ze when you cannot disconnect the bonding? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If you can see a piece of plastic entering from the ground then (as cliff said), it does not need main bonding. I think (not sure) this is reg...
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
