the best tap and die | Page 2 | on ElectriciansForums
Discuss the best tap and die in the Electrical Tools and Products area at ElectriciansForums.net
I do a fair bit of metal work and you need one of these https://www.amazon.com/Bare-Tool-Milwaukee-2625-20-One-Handed-Reciprocating/dp/B003EZWK42 saves so much time and effort, as for stock and dies the best ones I've used are all like 30 years old, as above though you need a decent cutting paste.
I still have my old ones from 30 years ago, still find Tallow one of the best cutting pastes.
With some cheap dies you may need to take the edge of the conduit so it "grips" when you first start.
I really need to find mine and clean them up, can't remember the make but I need to thank Matthew Hall for supplying them back in 1987.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Your stocks and dies should look like these....
Or you could get one of these beasts!......
yes mate my one its same as one on photo 1..the problem its element two on the picture..i dont know the exacly name ..they have to be 25mm wide but on most of them its 27mm wide..now when you try to thread conduit you cant thread properly them because its hard to keep exacly 90 degre to the conduit to make proper threding..for that i ask here if any one have this problem before and if its possyble to find one tap and die who its 25mm and not 27mm wide..
The guide will be slightly bigger than conduit, so 27mm sounds right. Could be the cutting die is blunt or the conduit isn’t cut square, making the thread start of angle.
Stupid question but have you put the die in the right way around?
Threading tool, consists of Stock, Die and Guide.
Just found my set way hey, similar to theses,
Set of 20mm & 25mm Stocks Dies and Guides - https://www.tlc-direct.co.uk/Products/COSDG.html?source=adwords&ad_position=1o1&ad_id=45425533757&placement=&kw=&network=g&matchtype=&ad_type=pla&product_id=COSDG&product_partition_id=174053414467&test=finalurl_v2&gclid=Cj0KCQiAv_HSBRCkARIsAGaSsrAygGQv4BArm5MQI-HF-E6K9ylpom0R3FAaCxjS-kcXRhzxhKrMtpQaAn7REALw_wcB
Reply to the best tap and die in the Electrical Tools and Products area at ElectriciansForums.net
£750 Aquataps or £2000 Quooker Tap £1000 Verana Tap What's Best? £750 Aquataps or £2000 Quooker Tap £1000 Verana Tap - Which is best? Been...
E
Mixer Tap Cartridge change advise. Hi Our kitchen mixer tap is leaking around the bottom. Unsure where the leak is coming from but suspect/hope a...
Eejay
E
