R
RISElectrical
By all account the tester has most items pre programmed in, press ac on the keypad and it come up with ac adaptor and remembers your last used location, for example office.
if.... and it is an if... what he says is true then 8 hours less lunch and breaks is 7 hours = 420 minutes. 600 tests at 10 seconds a test = 100 minutes leaving 320 minutes to unplug and plug back in appliances and check fuses.
This equates to approx 30 seconds to unplug, check fuse, plug back in again and attach pre printed sticker.
Now looking at this it could be possible however in a 7 hour working day it would be too much i think. he is probably under estimating how much he does or how long he works.
600 x 70p = 420 a day
600 x 80p = 480 a day
600 x £1 = £600 a day
and so on. personally i would work a 10 hour day for £600 thank you please.
