Things you see but cant believe!! | on ElectriciansForums
Discuss Things you see but cant believe!! in the Australia area at ElectriciansForums.net
C
chiplard
Can you spot the work of an idiot.
[ElectriciansForums.net] Things you see but cant believe!!
A categoric YES I think.
Hey it is all fine, there are no RCDs so it wont matter! (oops!)
Pity he ran out of green and yellow sleeving and forgot about correct termination with no copper showing!
I like what I assume is the main earth going round the CU to the left.
beautiful work, whoever did that is a credit to our profession. Hope you're picking up the sarcasm guys
I don't like the fact that not only has the order of the conductors in the neutral bar been interupted, but also the link will be interupted when the main switch is open.
Should have taken the link to the feed side of the main switch.
I would defy you or anyone else to terminate in one of those boards without any conductive part showing. Look at the terminal shrouding.
They were what we had available at the time.
MCB’s? Nobody trusted those foreign things in their house! I knew they were the way forward but after my mate’s house caught fire I didn’t trust them.
The worst thing about it n all is theres recent work gone on here (new colours but STILL no sleaving) whoever attempted to pull that new cable in to that shower of **** whants stopping as they should have either condemned it or sorted it all out first..........
Reply to Things you see but cant believe!! in the Australia area at ElectriciansForums.net
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t...
We have been through this debate at my local branch of the Men's Shed charity. It always seems to be the case that if you buy enrty-level gear you...
